Activity Forums Apple Motion Best export settings for FCP HD, DV format?
  • Best export settings for FCP HD, DV format?
    Posted by Sebastian Knight on June 10, 2005 at 8:15 pm
    I am using Final Cut HD in Tiger. I want to know the best Export Settings for Motion to use in FCP HD, also what is the best way you use a Motion Project in FCP HD?
    Thanks in advance for your reply to my Post,
    Sebastian
    Richard Harrington replied 21 years, 3 months ago 3 Members · 3 Replies
  • Tom Wolsky
    June 11, 2005 at 1:36 am
    Don’t export. Just import the Motion project into FCP.
  • Sebastian Knight
    June 13, 2005 at 1:41 pm
    How do import into FCP?
    Sebastian
  • Richard Harrington
    June 13, 2005 at 11:33 pm
    OH GOOD LORD
    FILE>IMPORT
    DRAG DROP
    RIGHT CLICK > IMPORT
    or RTFM as there is an ENTIRE booklet of info on integrating the two apps that comes with both of them in the box and is under the help menu electronically.
    The cow is not a replacement for a little bit of reading.
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro On The Spot & After Effects on the Spot
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.vasst.com
    edit – produce – direct –
