Activity Forums Avid Media Composer Best export setting for HD and Blue Ray DVD
  • Best export setting for HD and Blue Ray DVD
    Posted by Diane Gordy on April 15, 2009 at 5:37 pm
    Hi!
    I have a 720 HD project that i need to output to a hi-res HD DVD and a Blue Ray DVD using Toast.
    Right now, i’m exporting using the QuickTime Reff setting for the HD DVD. But I’m getting 2 files (.mov and .wav) and unable to combine both fles in Toast. If i do Same as Sorce, the color becomes very washed out. Is this the best export setting to use or should I use another?
    What is the best export setting I should use to burn a Blue Ray in Toast? I need to make the quicktime in Avid. I don’t have Encore, Compressor or Avid DVD.
    Thank You!!
    DGordy
    MacBook Pro OSX 10.5 2.6 GHz Intel Core 2 Duo 4 GB memory Media Composer 3.1.1
    Michael Phillips replied 17 years, 4 months ago 3 Members · 2 Replies
  • Grinner Hester
    April 15, 2009 at 11:49 pm
    you’ll just grab the mov file in toast. Audio will come with it.
  • Michael Phillips
    April 16, 2009 at 12:21 am
    Toast can take two files – I think they have to have the same name and be of a particular format. Check the help for exact steps.
    Michael
    Michael Phillips
