Activity Forums Apple Final Cut Pro Legacy Best Compression App?
  • Best Compression App?
    Posted by Michael Harrington on May 20, 2014 at 4:21 pm
    I’ve tried PAVTUBE, ProxyMill and a few others and all seem to have their own problems compressing and delivering what I need, simple things like recovering time code from original file.
    Whats a good fast compression software for Sony EX1 Camera BPAV files, GoPro MP4, Sony FS700 AVCHD to compress ProResLT, with original file name, TimeCode.
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Mavrick, ATI Radeon HD 4870, 30-inch Cine Display, 4 – 1TB internal, G Speed 6TB Raid 5, 1.25TB Esata, Numerous FW 800 external drives, Matrox MX02Max, FSI 17″ Broadcast Monitor, Black Magic Mini Sync Generator, Mackie 1402 & Event 20/20 monitors.
    Dino replied 12 years, 3 months ago 4 Members · 6 Replies
  • Shane Ross
    May 20, 2014 at 4:39 pm
    What’s your budget?
    https://www.root6technology.com/products/ContentAgent/
    Shane
    Little Frog Post
  • Michael Harrington
    May 20, 2014 at 4:46 pm
    I can’t afford Episode and I’ve tried a few $39 – $200 including ProxyMill but ran in to problems working with FCP 7 in 10.6.8, strange problems that make the developer scratch his head.
    I’m a week behind and need a good solid solution that will include timecode, import properly in to FCP 7 on 10.6.8, may upgrade osx to 10.8.6 as recommended by those still using FCP 7.
    Michael Harrington
  • Jeffrey Cornell
    May 20, 2014 at 7:22 pm
    MPEG Streamclip has never failed me!
  • Shane Ross
    May 20, 2014 at 8:46 pm
    MPEG STREAMCLIP doesn’t work with MXF nor AVCHD…
    Shane
    Little Frog Post
  • Jeffrey Cornell
    Woops.
    Sorry all. Read the original post wrong.
  • Dino
    May 21, 2014 at 5:42 pm
    There isn’t, that I’ve been able to find, one best program. I use a combination of Apple Compressor, DaVinci Resolve and After Effects. (and every once in a while, Sorenson Squeeze and Adobe Media Encoder). And when it’s easier, Log and Transfer or batch export in FCP 7. Some of these are slow and it’s best to leave a batch running overnight. Resolve has a bit of a learning curve but is surprisingly capable with the inclusion of LUTs and can be quite fast with the proper set up.
