Activity › Forums › Apple Final Cut Pro Legacy › Best codec?
Best codec?
Posted by Chris Balogh on May 14, 2009 at 5:25 pmI have quicktime movie. It is all cgi made in lightwave at HDV quality 1280×720 30frames. Yet, the customer has to have it at 720×480 and it will not be played on HD quality devices. So, what is the best encoding process/codecs/ the whole kitten kaboodle for this type of file?
Thanks in advanceMichael Sacci replied 17 years, 4 months ago 3 Members · 5 Replies -
John Fishback
May 14, 2009 at 5:42 pmHow’s it going to be played? From the computer, a DVD? In addition to it being SD, what are the delivery specs?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Michael Sacci
May 14, 2009 at 6:02 pmGo back and start with a better codec out of Lightwave, HDV is the worse possible choice for graphics or animation.
10-bit Uncompressed SD would be a great and safe choice and will go to m2v (for the DVD) the best.
Michael Sacci
May 14, 2009 at 7:01 pmIf need to post complete info,
[Chris Balogh] “I correct myself it is m2v”
what is IT, the export, the client’s need?If the client needs a SD movie to go on a DVD, will they be doing the m2v encoding, if so what system are they on, which will determine want codec is best.
Also if your animation is truly 30 fps it will need to be retimed, DVD video has to be 29.97, not a big deal but your audio needs to be retimed to match.
