Activity › Forums › Apple Final Cut Pro Legacy › best codec to capture HDCAM with a Aja Kona LHe
Posted by Martial Bachoffner on February 26, 2008 at 6:38 pmHello,
I would like to have your advice on which codec to use to capture HDCAM footage, directly from the camera using an Aja Kona LHe.
The Aja Kona LHe is only 4:2:2, I was thinking using Apple ProRes HQ.
Since I read that there is some bug with ProRes, I was thinking using 10-bit uncompress. Even if the card is only 4:2:2, I think graphics and text will looks better.Also, which raid system do you recommand to handle it? I started to look the G-Speed XL 16TB with 2B of cache with fiber channel.
Regards,
MartialVancouver Island Final Cut Pro User Group
Martial Bachoffner
Founder and AdministratorJeremy Garchow replied 18 years, 7 months ago 6 Members · 15 Replies -
David Roth weiss
February 26, 2008 at 6:46 pm[Martial Bachoffner] “I read that there is some bug with ProRes”
What bug? Please expand on that one…
ProRes would certainly allow you to use a much less expensive raid that 10-bit uncompressed.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Shane Ross
February 26, 2008 at 6:55 pmI recommend the Caldigit HDPro. 4 times faster than Fibre channel, and pretty rock solid. I have a review here at the Cow. They have a cheaper version called the HDOne…jsut as fast, just slightly less features and redundancy.
Also look at Sonnet 800P and Maxx Digital for solutions.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Galen Fletcher
February 26, 2008 at 7:29 pmWe use uncompressed 10 bit 4:2:2 with a Cal Digit HDpro. Although HDCAM is only 8 bit, we prefer 10 bit for VFX and Colour correction, however I’m not sure how much difference it really makes.
Martial Bachoffner
February 26, 2008 at 8:01 pmIt was on another forum, they just said there is bug with the ProRes without to give any precision.
Thanks all for your answers.
Regards,
Martial Bachoffner
Founder and Administrator -
Jeremy Garchow
February 26, 2008 at 9:03 pmProResHQ. Uncompressed 10bit is a bit of a bear to work with on an editing basis. Great to finish with but not to edit.
Jeremy
Martial Bachoffner
February 26, 2008 at 9:18 pmThanks Jeremy!
Regards,
Martial Bachoffner
Michael Gissing
February 26, 2008 at 9:19 pmCapturing straight off the camera is a potential disaster. The editing codec is one question but the real problem will be the ability to recapture.
Straight off the camera will give you no device control and therefore no timecode if you recapture.
Uncompressed is huge so unless this is a very short project you will rapidly fill expensive RAID drives. I use uncompressed to recapture final edits but never would consider it for editing.
Jeremy Garchow
February 26, 2008 at 9:31 pm[Michael Gissing] “Capturing straight off the camera is a potential disaster. The editing codec is one question but the real problem will be the ability to recapture. “
Using the LHe and AJA VTR Exchange, you should be able to pick off the RP188 tc.
If not, you can use on ioHD that will either pick off the rp188 or you can send LTC to it and capture that with a laptop and a 2 drive SATA array (I have done this and it is awesome). You get hardware ProResHQ encoding with the ioHD.
OR you can use the adreilec mbox https://www.adrielec.com/
It’s not as hard as you’d think and can be done on a laptop now-a-days.
Jeremy
Michael Gissing
February 26, 2008 at 10:11 pmInteresting Jeremy. Thanks for that. I hope Martial and others take note.
However, my experience so far is that uncontrolled device is the way editors have so far dealt with this type of capture and of course I get to find out about it months later doing the online.
Martial Bachoffner
February 26, 2008 at 10:18 pmThey have aery good article at: https://www.adrielec.com/final_cut_pro_guide.htm
Regards,
Martial Bachoffner
