Activity Forums Apple Final Cut Pro Legacy best codec to capture DV footage?
  • best codec to capture DV footage?
    Posted by Zeliha Bozkurt on February 17, 2007 at 9:59 pm
    Hi
    I have some tapes coming in on DVCAM/DV to edit with. As it is a 2 day edit I want to digitize it in at online resulution.
    I have Blackmagic Decklink HD Pro Dual Link card.
    I wil either use Sony HVR M25 E and digitize it firewire or I the Panasonic AJ-1400 and digitize it SDI. it will depend on deck availability.
    Would it be Uncommpressed 8 bit(firewire) or Blackmagic NTSC DV uncompressed 8 bit (SDI). Not sure.
    Zee :0)
    Dkilgore replied 19 years, 7 months ago 3 Members · 2 Replies
  • Dan Riley
    February 18, 2007 at 4:56 am
    Digitize at whatever codec your sequence is going to be.
    Bringing it in SDI 8 or 10 bit makes good looking video.
    I do it all the time with my DV footage.
    As long as your drives are fast enough for uncompressed
    you will be fine.
    Dan
  • Dkilgore
    February 18, 2007 at 6:56 am
    uncompressed 8bit or 10bit if you will be doing a lot of color correction/compositing
    Donald Kilgore
    Image202 Entertainment
