Activity Forums Apple Final Cut Pro Legacy Best Codec for large screen
  • Best Codec for large screen
    Posted by Mike Rakoff on February 12, 2013 at 9:13 pm
    Hello –
    I’m sure this is asked a lot but I have edited a web series and am now cutting it into a feature which will air on the big screen.
    It was shot on 5D H.264 / 1920 × 1080. Then transcoded into AppleProRes 422 for the web. I wanted to re-encode the episodes into a better/higher quality. Does anyone have any recommendations?
    Mike
    Mike Rakoff replied 13 years, 6 months ago 2 Members · 4 Replies
  • Shane Ross
    February 12, 2013 at 11:50 pm
    ProRes 422 isn’t for the web…it’s for editing, and mastering…delivery for broadcast. If you plan on going to the web, re-encode back to H.264.
    Is that BETTER than ProRes in terms of quality? No. ProRes has a higher data rate and is better quality by far. But the web players don’t play back ProRes. They play back H.264…either as Mp4, MOV or flash.
    Shane
    Little Frog Post
  • Mike Rakoff
    February 13, 2013 at 12:33 am
    Hi shane,
    Sorry I didn’t specify. I have already re-encoded from Pro Res back to H264 for youtube.
    Though my question is, if I should use a different codec for film festivals now, which will no doubt be screening this on a large screen?
    Basically, can I and/or should I upgrade my workflow from prores422 to another codec? One more suitable good quality once the file is enlarged?
    Mike
  • Shane Ross
    February 13, 2013 at 1:05 am
    ProRes 422 is a finishing codec. It is often asked for as a final deliverable for film festivals and broadcast. Re-encoding what you have to any other codec will not increase the quality in any way.
    Shane
    Little Frog Post
  • Mike Rakoff
    February 15, 2013 at 6:18 pm
    Okay, thanks Shane! BTW does that also include going from ProRess422 to ProRes422 (HQ) or 4444?
