Activity › Forums › Panasonic Cameras › best codec for dv capture?
  • best codec for dv capture?
    Posted by Zeliha Bozkurt on February 17, 2007 at 9:45 pm
    Hi
    I have some tapes coming in on DVCAM/DV to edit with. As it is a 2 day edit I want to digitize it in at online resulution.
    I have Blackmagic Decklink HD Pro Dual Link card.
    I wil either use Sony HVR M25 E and digitize it firewire or I the Panasonic AJ-1400 and digitize it SDI. it will depend on deck availability.
    Would it be Uncommpressed 8 bit(firewire) or Blackmagic NTSC DV uncompressed 8 bit (SDI). Not sure.
    Zee :0)
    Zeliha Bozkurt replied 19 years, 7 months ago 2 Members · 2 Replies
  • John Sharaf
    February 17, 2007 at 10:45 pm
    Zeliha,
    The whole idea of “DV” (and subsequently DVCPRO) is to import, edit and export in the “native” codec. This way there is no longer any destinction between “off-line” and “on-line”; you only edit once.
    It is therefore the normal workflow to do all this without “converting” to SD or HD-SDI at least until the output. This will preserve the quality best!
    JS
  • Zeliha Bozkurt
    February 18, 2007 at 12:31 pm
    Hi John
    Thans for the reply
    [john sharaf] “The whole idea of “DV” (and subsequently DVCPRO) is to import, edit and export in the “native” codec.”
    Does the above mean use DV NTSC codec via firewire?
    Zee.
