Activity › Forums › Adobe After Effects › best cache settings on mutilple drives
Posted by Dan Roth on March 4, 2010 at 7:54 amHi everyone! I just bought a new computer with 3 drives and want to know where to set the default cache and rendering output locations to get maximum speed on renders. I have a C drive (250GB) for system programs; D drive (1TB) for storage and E drive (1TB with Raid 0 for mirror backup) for my AE files and other documents.
Please advice.
ThanksWalter Soyka replied 16 years, 6 months ago 2 Members · 3 Replies -
Walter Soyka
March 4, 2010 at 2:23 pm[Dan Roth] “I just bought a new computer with 3 drives and want to know where to set the default cache and rendering output locations to get maximum speed on renders.”
I believe the recommended configuration in a 3-drive setup is one drive for the system and apps, one for footage, and one for renders. In other words, if you kept your footage in the D drive, render to the E drive.
It depends on the sort of work you do, but very few of my renders are disk-bound — they are all either CPU- or RAM-bound. Hopefully, your new computer has plenty of cores (quad-core or dual quad-core) and 2-4 GB of RAM per core for efficient multiprocessing.
[Dan Roth] “I have a C drive (250GB) for system programs; D drive (1TB) for storage and E drive (1TB with Raid 0 for mirror backup) for my AE files and other documents.”
Just a quick note on RAIDs — please pardon me if I’m responding to to a typo.
RAID-0 is striping, not mirroring; it spreads the data across two or more disks for added speed, but there is no redundancy. If one drive fails, you lose the entire data set. RAID-1 is mirroring, which means one write is committed to multiple drives at the same time; if a drive in the set fails, you still have all your data on at least one other drive.
Also, I cringe when I see “RAID” and “backup” in the same sentence. RAID-0 has no redundancy. RAID-1 has redundancy, but if you accidentally delete a file on RAID-1, it’s immediately gone from all disks in the set. Even in a RAID-5 setup, if your controller fails, you could immediately lose your data.
RAID in most levels (not 0) provides redundancy that protects you against a single disk failure, but that’s all. It does not protect against catastrophic failure, user error, or plain bad luck (like simultaneous failure of multiple drives).
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Dan Roth
March 4, 2010 at 2:33 pmthanks for explaining that. yes i do keep backups on external drives besides the raid,which is mirrored.
Another thing: why when AE starts up does it say ‘2% of 4gb of ram used’ when i have 12 gb of ram. I’m using windows 7 64 bit with 12 Gb ram and i7 8 core.
And finally, what about the scratch drive? i keep my footage of the e drive and will render out to the d drive. where does scratch fit in to all this?
thanks for your patience…
Dan -
Walter Soyka
March 4, 2010 at 2:49 pm[Dan Roth] “why when AE starts up does it say ‘2% of 4gb of ram used’ when i have 12 gb of ram. I’m using windows 7 64 bit with 12 Gb ram and i7 8 core.”
AE CS4 is a 32-bit application, so it can only address 4 GB of RAM. (CS5 will be 64-bit, and will be able to address much, much, much more).
To get around this limitation, AE’s multiprocessing feature launches multiple instances of the After Effects rendering engine — one per core. Each instance will work on one frame at a time, and each instance can grab up to 4 GB of RAM. This is why having lots of RAM is so important in a multi-core system.
See multiprocessing for more.
[Dan Roth] “And finally, what about the scratch drive? i keep my footage of the e drive and will render out to the d drive. where does scratch fit in to all this?”
I assume you’re talking about the disk cache? It’s only used for standard previews (not for RAM previews). I don’t generally use standard preview, so I leave mine off. If you enable disk cache, it should probably be on your render drive, not the source drive.
Walter Soyka
