Activity Forums Compression Techniques Best Bitrate for H.264 HD Video included in DVD-ROM
  • Best Bitrate for H.264 HD Video included in DVD-ROM
    Posted by Adam White on February 13, 2010 at 8:48 pm
    Hello CC Experts,
    I’m preparing preview copies of a short film, to be distributed to various festivals over the coming months.
    I’m sending Standard Definition DVD’s (not yet geared up for Blu-Ray and HD-DVD is now a defunct format) but will also be including some DVD-Rom content on the disc. This will include Press Packs and High-Resolution still from the film, and I’m hoping to also add in a High Definition .MOV of the film itself.
    H.264 seems to be the best compression method for this (widely accessible to end-viewer; great image quality and small file sizes), but I was wondering what birate you would recommend? Image quality is hugely important – but I don’t want to set the bitrate too high and cause the video to choke the DVD-Drive of a computer when viewed. From Compressor, I see that the max. Bitrate for H.264 files encoded for Blu-Ray is 30,000kbps – is this a good rule of thumb to go by or am I way off track? By the way – I have just over 3GB available space on the DVD-R for the HD Video, and the film is just over 10 Minutes so file size isn’t a big concern.
    Thanks in advance for any advice!
    Rich Rubasch replied 16 years, 6 months ago 2 Members · 3 Replies
  • Rich Rubasch
    February 13, 2010 at 9:47 pm
    What frame size are you going to shoot for? This will sort of determine what bitrate you will want to hit. I would doubt that off a standard DVD disc that much over 5 megabits would play well.
    As for making a nice looking BluRay disc for those that can play them Toast 10 is a very simple way to make a standard BluRay disc burned onto a standard DVD-
    R disc. It’s very easy to do and looks great. Don’t use menus and make the disc a first-play and you will have nearly 100% compatibility.
    Good luck with the film.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Adam White
    February 13, 2010 at 10:38 pm
    Thanks for your response, Rich.
    With an upper limit of 5 Megabits – I think I’ll probably just give this a miss, then. It isn’t required by any of the festivals we’ve got lined up – I was only going to do it as an extra.
    However – your suggestion to use Toast may very well come in handy later down the line. I’m only on a iMac with Standard DVD drive, though – won’t I need an external BluRay burner to make a BR disc?
    Thanks for your input – really appreciate it. Nice showreel at Tilt Media btw – I’m on the other side of the pond, so it’s nice to see how the BBC promotes its content abroad (Lost in Austin e.t.c.)
    Best,
    Adam
  • Rich Rubasch
    February 14, 2010 at 1:39 am
    Just read that a standard DVD-R has a max of 10,000 megabits but that is a max.
    And with Toast you can burn a fully qualified BluRay disc onto a DVD-R with a standard DVD burner.
    Thanks for the kind words on the site. We are pleased to have BBC Sales Company as one of our largest clients. But we deserve it. : )
    Rich Rubasch
    Tilt Media Inc.
