Activity › Forums › Apple Final Cut Pro Legacy › Best Betacam SP capture resolution
  • Shane Ross
    February 11, 2011 at 5:36 am
    Well, BetaSP is an 8 bit format, so capturing 8-bit uncompressed would get you the same results as 10-bit uncompressed. But really, you need very fast drives for uncompressed. Look at ProRes NTSC…the SD ProRes setting. 10-bit quality but lower data rate. It’ll look the same.
    Shane
  • Ian Liuzzi-fedun
    February 11, 2011 at 5:37 am
    8 bit uncompressed it is
  • Steve Eisen
    February 11, 2011 at 12:18 pm
    Shane is telling you to use ProRes 422. It’s a 10 bit quality with a lower data rate than 8 or 10 bit uncompressed.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Ian Liuzzi-fedun
    February 13, 2011 at 1:59 am
    I can read and do understand this. Thank you both
