Activity Forums Maxon Cinema 4D Best Approach
  • Best Approach
    Posted by Paul Minotto on May 2, 2015 at 7:17 pm
    I’m trying to reproduce this house that was modeled in Vectorworks. I’m not interested in the line quality, just the basic 3d forms.
    Would i start with a spline for the floor plan and then extrude for the walls? If so, the wall height is variable, how would i create the part that meets the roof?
    And the roof, what would be the best way to model that?
    Thanks.
    Paul Minotto replied 11 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 3, 2015 at 12:32 am
    make the extruded walls high enough for the highest point (or higher) then use the roof (or a copy of the roof) to cut the walls (with a Boole) – then you just remove the extra part left over at the top.
    Modelling the roof depends on what it’s shape really is because there are a lot of ways that could be used.
  • Paul Minotto
    May 4, 2015 at 9:15 pm
    Thanks for your help Brian.
