Activity › Forums › Adobe After Effects › Best affordable Nvidia graphics card for AE CS6 and above
  • Best affordable Nvidia graphics card for AE CS6 and above
    Posted by Daniel Futerman on July 28, 2013 at 3:25 pm
    Hey all,
    I’m planning to upgrade to After Effects CS6 / CC and upgrade my graphics card.
    For the past 3 years I’ve being using AE CS5 + Nvidia GTS 250, and all in all I was happy with the workflow and speed.
    So basically, I’ve started looking into new graphic cards and I’d like one that is supported / recommended by Adobe (https://www.adobe.com/il_en/products/aftereffects/tech-specs.html), but yet I still want to stay withing a resonalble budget of +/- $500.
    I’d be really happy to hear which card you guys recommend within this budget.. Obviously I’d like it to be as powerful as possible considering CC has cinema 4D Lite which I assume needs quite a lot of ‘power’.
    Thanks a lot! Any help much appreciated.
    Professional Multimedia Solutions:
    https://www.DanielFuterman.com
    Adobe Video Tutorials:
    https://www.amigo-productions.com
    Michael Szalapski replied 11 years, 7 months ago 6 Members · 18 Replies
  • 18 Replies
  • Todd Kopriva
    July 28, 2013 at 6:53 pm
    Any of the GTX 5xx and 6xx cards are a good choice for performance/price.
    See Danny Princz’s benchmark test results here:
    https://docs.google.com/spreadsheet/lv?key=0AuE_AZZfskx3dHotTzVGamhiUkIySTUteGlzeG9xMEE
    After Effects team blog
  • Daniel Futerman
    July 29, 2013 at 8:30 am
    Many thanks for your help Todd.
    I had a look at the benchmark test (awesome work there by Danny Princz), and had a difficulty at deciding which parameter is most important. What I would think is that it all comes down to render time. The faster the render time is, the better the graphic card is. But since I’m not really a technical guy, I’m not sure if that assumption is correct?
    Also, this might be a dumb question, but in the Value (price vs performance) tab, do I want the number to be high or low? i.e. is 1.38 better than 0.96?
    My humble conclusion based on the benchmark tests is that for a price lower than $500, the GTX670 is one of the best options.
    I’d love to hear your opinion on this!
    It’s probably also important to note that I’m using Windows 7 64bit, i7 920 @2.67 GHZ, 12GB ram.
    Members
  • Daniel Futerman
    July 29, 2013 at 10:49 am
    Hmm actually.. I don’t see the GTX 670 on the recommended list of Adobe here..
    Is it still ok? Or will I be limited in some way?
  • Todd Kopriva
    July 29, 2013 at 8:05 pm
    The GTX 670 is listed on the system requirements page here:
    https://www.adobe.com/products/aftereffects/tech-specs.html
    The page that you linked to is stale and needs to be fixed.
  • Daniel Futerman
    July 30, 2013 at 4:47 pm
    Great, thanks Tod!
    So just to sum up this post, does anyone have experience with the gtx 670? Should I buy it or is there a better option for approx. the same price of $399?
  • Ericbowen
    July 30, 2013 at 7:25 pm
    The 670GTX or 770GTX would be the 2 options. The 770GTX is not on the supported list yet I believe but likely will be soon. I would however look at 24GB of ram before investing to much in the GPU.
    Eric-ADK
    Tech Manager
  • Todd Kopriva
    July 30, 2013 at 8:47 pm
    Have you been peeking at my list of cards to test? 😉
    That is excellent advice.
  • Daniel Futerman
    July 31, 2013 at 8:30 am
    Thanks for your advice Eric.
    I think I’ll go ahead and purchase the GTX 670, and look into getting 24GB of ram.
    Appreciate your help guys, thanks!
  • Sylvain Hugues
    October 4, 2014 at 10:15 pm
    Why 24GB of ram are so important ?
    If I create 3D animation and HD after effects, the video card will be as much important.
    You mean a good video card with 8 or 16 gb ram would be a waste ?
    Merci, Sylvain
  • Michael Szalapski
    October 6, 2014 at 4:27 pm
    [sylvain hugues] “Why 24GB of ram are so important ?
    You mean a good video card with 8 or 16 gb ram would be a waste ?”
    The GPU does very little for After Effects, see here [link]
    RAM and processor power are much more important.
    For the most part, the GPU only matters in After Effects if you’re using the (obsolete) ray-traced 3d renderer or certain third-party plugins (like Element 3D from Video Copilot). And, if you are using third-party plugins, AE’s tested GPU list doesn’t matter (since it’s only testing to work with the ray-traced renderer). You should just focus on what the third-party plugin recommends.
    Now, the GPU does matter very much for Premiere. So, if you use Premiere, look at Premiere’s requirements, any third-party plugin requirements, and requirements for any other software you might run on your system and you’ll be fine for AE too.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
