Activity › Forums › Apple Final Cut Pro Legacy › Best 19-20 inch screens CRT, LCD
  • Best 19-20 inch screens CRT, LCD
    Posted by Drizzt_g on September 25, 2005 at 8:02 pm
    I’m looking for a a good dual display setup for FCP. I know CRTs are still considered excellent and they last for a long time. LCDs are getting cheaper and they look great.
    By the way I will have a seperate unit for monitoring.
    Right now I’m thinking about:
    CRTs: dual Dell M993 19-inch Color Flat CRT Monitors
    LCDs: dual DELL UltraSharp 1905FP 19-inch Flat Panel
    What do you think.
    Mitchji replied 21 years ago 4 Members · 3 Replies
  • Ernie Santella
    September 25, 2005 at 9:19 pm
    I’ve worked on both monitors and find CRT’s still a better choice. I know, many will disagree, but myself, I do a lot of Photoshop & After-Effects work. And I do depend on the image on the computer screens being accurate while working, before I see the final result displayed on the NTSC monitor later.
  • Marco Solorio
    September 26, 2005 at 9:02 am
    [Ernie Santella] “And I do depend on the image on the computer screens being accurate while working, before I see the final result displayed on the NTSC monitor later.”
    CRT or LCD, this is still an RGB preview rather than a true Y’CbCr preview with chrominance sub-sampling. If you want an accurate viewing of your NTSC/PAL material, then one must view it on an NTSC/PAL monitor. Aurora and DeckLink have the least expensive solutions for this need. Viewing accurate colors early on saves time in the end.
    As anyone might know, I cannot recommend the Dell 2001FP monitors enough for computer use. I have over a dozen of these in my facility. I think they’re an even better buy than the newer 2005FP monitors. For video monitoring, the Sony PVM20L5/1 is my monitor of choice.
    Marco Solorio  |  OneRiver Media
  • Mitchji
    September 28, 2005 at 6:09 am
    Check here for deals on Dell monitors:
    https://dealmac.com/sections/displays-TVs.html
    Current deals are:
    https://dealmac.com/deals/Dell-Ultra-Sharp-20-1-widescreen-LCD-display-for-499-standard-20-for-464/96296.html
    10:01 am ET, Sep 23, 2005; expires 6:59 am ET, Sep 29, 2005
    Dell UltraSharp 20.1″ LCDs
    Dell Home offers the Dell UltraSharp 2005FPW 20.1″ Widescreen LCD Monitor (pictured) for $699. Coupon code “LZZNW2HFTM0LLM” drops it to $499.20. Add $2.60 for shipping and handling. It’s tied for the lowest total price we’ve seen since mid-August.
    Also available: the Dell UltraSharp 2001FP 20.1″ LCD for $464.30 after the same coupon code. That’s the lowest price we’ve seen since July.
    The 2005FPW sports a native resolution of 1680×1050 while the 2001FP has a native resolution of 1600×1200. Both feature USB hubs and S-Video, composite video, DVI, and VGA inputs. Deals end September 29 at 7 am ET or at 7,000 uses.
    Best Wishes,
    Mitch
