Activity Forums Adobe After Effects Bending Text around a corner
  • Bending Text around a corner
    Posted by Ken Latman on September 15, 2005 at 6:33 pm
    I’m having some difficulty trying to create an effect.
    I want to take a line of text and have it go around a cube but as it goes around the text bends at the edges. This is similar to how the news ticker looks on one of those buildings in New York.
    Are there any tutorials how to do this or any ideas? I’ve looked at several of the distort filters and tried making my text layer into a 3D one. I have the Production Bundle but no other plug-ins. I’m not lookng to purchase a plug-in either.
    Any Ideas are greatly appriecated.
    Mark Von wahlde replied 13 years, 11 months ago 5 Members · 5 Replies
  • Guy
    September 15, 2005 at 7:45 pm
    you need to warp, or bend a layer in 3D space.
    CC Cylinder comes with After Effects and will bend it into a cylindrical shape, but you are limited to a cylinder.
    A 3rd party plugin, Forge Freeform, will allow you to warp a layer in 3D space.
  • Bobby Walker ii
    September 16, 2005 at 12:02 am
    Try this oldie but goodie post from Mr. Rick Gerard…
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=651159&archive=T
    hth
    bobby walker ii
    broadcast video COW
    G5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
  • Roland R. kahlenberg
    September 16, 2005 at 5:00 am
    You’ll first need to use either Offset or Motion Tile to animate your text in a scrolling, ticker-tape manner. Once, you’ve got that, turn the layer into a 3D layer and adjust Orientation (Y-axis) to your liking. Duplicate the layer. Adjust the Anchor point of the duplicate so that it is vertically centered either at the left-most (or right-most – depends on your setup) side of the layer. Then adjust Orientation (Y-axis) for this layer so that it forms a right-angle with the original layer.
    Thereafter, you only need to stagger the start point of one of the layer’s – IOW, both layers shouldn’t start at the same point in time – this trick ensures that the animated text looks like it is moving across both layers in ONE move. Once you’ve got the stagger done correctly, the text should animate around the corner, across both layers, perfectly.
    Hope all this makes sense. Good Luck.
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files.
  • Ken Latman
    September 16, 2005 at 12:40 pm
    Thanks so much for the info. Rick’s little file helps me so much. It breaks it down better then than what I was trying to do. Sometimes simpiler is better.
    I only wish I had searched cow more throughly. Maybe there could be a wikipedia type section for cow for tutorials or techniques. Just an idea.
  • Mark Von wahlde
    September 22, 2012 at 11:11 pm
    This post was very helpful, but I needed to precompose each layer to make it work.
