Activity › Forums › Adobe After Effects › Bending or deforming a 2D image or layer in 3D space
Posted by Blake Goedde on October 7, 2013 at 4:43 pmI’ve been searching for hours upon hours for a solution to this problem, but I can’t seem to find one. Basically I need this logo (https://www.youtube.com/watch?v=bHSdLlp4hvM&feature=youtu.be) to bend when flying in a circle. I’ve seen that Zaxwerks 3D warps is a popular suggestion, but I don’t have the money and the demo leaves watermarks. If there is any free solution can someone please help me out? I’m at a loss.
Chris Bobotis replied 12 years, 11 months ago 5 Members · 8 Replies -
Walter Soyka
October 7, 2013 at 5:26 pmSome clever application of CC Cylinder should do the trick.
Depending on your version of Ae, you may have Freeform bundled, which would also be a good choice.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Todd Kopriva
October 7, 2013 at 9:33 pmYou can bend 2D layers in 3D using the ray-traced 3D renderer:
https://www.video2brain.com/en/lessons/bending-2d-layersIt’s limited, but it may be enough for you.
Walter’s tip about the CC Cylinder effect is also good.
After Effects team blog
Blake Goedde
October 8, 2013 at 12:33 amI unfortunately have CS5.5. I tried Walter’s tip and it produces too flat a look. I suppose I could keep trying, but I’m looking for some true 3D deformation. I guess AE doesn’t offer much of that by default
Walter Soyka
October 8, 2013 at 2:10 am[Blake Goedde] “I unfortunately have CS5.5.”
Then you have FreeForm bundled. Try that.
[Blake Goedde] “I tried Walter’s tip and it produces too flat a look.”
You want the logo to wrap in 3D space and have depth? That’s a job for a full 3D application.
Walter Soyka
Todd Kopriva
October 8, 2013 at 2:55 am> That’s a job for a full 3D application.
… and we include one of those now.
Blake Goedde
October 8, 2013 at 3:44 amI’ve tried FreeForm as well. I feel like it could work, but I can’t seem to adjust in from any camera but the front. https://i.imgur.com/fRJrykn.png
If you saw the video from my first post, then that was rendered from the view on the left. The view on the right is just the top of the 3D composition and you can see the motion path I want the logo to bend around. My problem with using FreeForm is that I can’t seem to manipulate the grid or do anything other than highlight the grid points in the top view. I can warp the image using FreeForm all I want in the front view, but whenever I try to use it from the top view, which I guess is my “camera1,” then nothing budges.https://i.imgur.com/fRJrykn.png
For some reason my links aren’t working in this forum
Tudor “ted” jelescu
October 8, 2013 at 11:28 amHere’s a tutorial that uses Free Form- maybe that will give you some pointers:
https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
Tudor “Ted” Jelescu
Senior VFX Artist -
Chris Bobotis
October 8, 2013 at 11:50 amDigieffects FreeForm was bundled with CS 5.5 as well. Not CS6 (+later). FreeForm V2 is for CS6 and up (available at mettle.com)
Just guessing here but I think you may be applying FreeForm to an AE 3D layer. This is not a good idea as it would produce unexpected results. All 3D plug-ins should be used on AE 2D layers to work properly. This includes the Trapcode products, Element 3D and even AE’s own 3D plug-ins like Shatter. You can definitely do true 3D with all Mettle plug-ins for AE. There is no 2.5D trickery going on with our stuff. We run a full and robust 3D engine in our plug-ins.
HTH
Cheers,
Chris
mettle.com
