Activity › Forums › Maxon Cinema 4D › Bending an extruded object
  • Bending an extruded object
    Posted by Rohan Guha on June 19, 2017 at 8:33 am
    Hey C4D community, I just made these tire tracks or treads or whatever they’re called and I wanted to bend it to make a tire but when I use the bend, some weird stuff happens instead of it bending to make a circle shape. It bends the entire object instead of making it like a circle.
    Thanks in advance for the help
    Rohan Guha replied 9 years, 3 months ago 2 Members · 4 Replies
  • Brian Jones
    June 20, 2017 at 12:45 am
    just one forum note, you should copy/paste the links the load mechanism gives you back into your post, otherwise people have to click on your name to find the files you uploaded…
    The bend needs to be bigger than the object to be bent (or ideally just bigger) – that’s what the Fit To Parent button in the Bend/Object tab is for. Also the Bend needs to be rotated (probably -90° in B) but do that before you change the size to match the object.
    11455_bendtoatube.c4d.zip
  • Rohan Guha
    June 20, 2017 at 6:39 am
    Here are the pictures
  • Rohan Guha
    June 20, 2017 at 6:43 am
    Hey Brian, thanks for replying. I did try what you did by fitting it to parent but it didn’t work well. I’ll attach the cinema 4d file link here. Please see if you can spot the problem.
    11456_195172.c4d.zip
  • Rohan Guha
    June 20, 2017 at 8:36 am
    My bad, I forgot to rotate the bend object. Thanks for the help!!!
