Activity › Forums › Adobe After Effects › Bending An Arrow
  • Michael Bugera
    July 20, 2006 at 5:55 pm
    That is: A STRAIGHT arrow.
  • Fabiano Peres
    July 20, 2006 at 6:18 pm
    Try to use the CC Cylinder effect, if you just want to bend it a little bit create a big comp and pre-compose it before you apply the effect.
    Please, let me know if it helped.
  • Mike Clasby
    July 20, 2006 at 6:22 pm
    Depends on how you want to bend it.
    CC Bender or Corner Pin… Maybe mesh warp…
  • Thehardmenpath
    July 21, 2006 at 6:58 am
    You can make an arrow by adding the stroke filter to a mask and then animate the vertices with bezier curves.
