Activity Forums Adobe After Effects Bending a layer in a straight angle
  • Realethan
    February 17, 2006 at 6:32 pm
    Try the “Wave Warp” effect.
    -Set the “Wave Type” to “Triangle”
    -Set the “Wave Width” to 1/2 the actual width of your comp (or use Height if you want to bend it the other way)
    -Then play around with the “Wave Height” until you achieve the angle you want.
