Activity Forums Maxon Cinema 4D bend deformer issues!
  • bend deformer issues!
    Posted by Rachel Max on June 9, 2006 at 11:13 pm
    Yar – I know i built this file in a kind of weird way – but total newbie here. Anyway – I am trying to bend a cylinder and the bend is affecting other areas of the “pipe”. It worked fine on the yellow pipe – but is not working on the blue pipe. You can see at this link – the top image is what is happening and the bottom image is what the lower art of the pipe needs to look like.
    Is there a way to stop this from happening. For some reason I had no problem with the other pipe.
    Thanks in advance,
    Rachel
    https://www.rachelmax.com/c4d_issue.html
    Rachel Max replied 20 years, 3 months ago 1 Member · 1 Reply
  • Rachel Max
    June 9, 2006 at 11:24 pm
    SORRY – figured it oout. Hierarchy thing.
    Thanks – Rachel
