Activity Forums Apple Final Cut Pro Legacy Behind The Scenes Film Footage / FCP Settings
  • Behind The Scenes Film Footage / FCP Settings
    Posted by James Carter on May 22, 2009 at 9:16 pm
    I’ve been asked to submit some footage to a studio in h.264 1080p 23.98 NDF?
    When exporting in FCP as a Quicktime?
    Are these the right custom settings? Do they make any sense lol?
    frame size: hd 1280×1080
    pixel aspect ratio: 1440×1080
    editing timebase: 23.98
    timecode rate: 30NDF
    compressor: h.264
    Any help would be much appreciated?
    Rafael Amador replied 17 years, 3 months ago 2 Members · 2 Replies
  • James Carter
    May 23, 2009 at 2:25 pm
    Is it possible to get any help on these export settings? I would appreciate it greatly.
    -Jim
  • Rafael Amador
    May 23, 2009 at 3:49 pm
    Hi James,
    You need to export:
    frame size: 1920 x 1080
    pixel aspect ratio: Square (1920×1080)
    timecode rate: 23’98 (Current)
    compressor: h.264 > Key Frame Automatic> Frame Reorder> Double Pass.
    For that size a data rate try 20.000 Kbps. you an increase it.
    If your video is 1440×1080 and you want to go 1920×1080, Compressor (With the Frame Control ON, and Resize Filter: BEST) will make a better job than FC.
    Cheers,
    Rafael
    http://www.nagavideo.com
