Activity Forums Adobe After Effects Beginning a Comp
  • Beginning a Comp
    Posted by Jason Ridgeway on September 12, 2012 at 5:37 pm
    I have recently switch to CS5 from 6.5. Thing were going well with CS5 but now when I open a comp. and make any kind of layers I can not see them or anything that I am doing. Its like I have a solid black layer that I can not shut off. I have done everything that I can think of to make the layers visible but with no success. Anyone had this problem or knows how to make go away? Thanks!
    Riley Beach replied 14 years ago 3 Members · 2 Replies
  • John Cuevas
    September 12, 2012 at 6:15 pm
    A screen shot would be helpful to see if you have accidentally turned something on or off, but the first thing I would check is to see if you have the Region of Interest(ROI)enabled. It’s below your comp window and the icon looks like a picture-in-picture graphic.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Riley Beach
    September 13, 2012 at 12:13 pm
    Do you have a comp viewer open, or are you looking at a layer window?
    Try setting your workspace back to default (window > workspace > reset “standard”).
