Activity Forums Maxon Cinema 4D Beginner question: Take an object out of the edible phase?
  • Beginner question: Take an object out of the edible phase?
    Posted by David Grush on October 25, 2015 at 2:03 am
    So pressed “c” to make an object editable to change some of it’s properties. Now it’s unaffected by the pose tag. What can I do to make it stop being editable, so the pose tag works?
    screenshot: https://gyazo.com/f7fdc60ec4a0b5db2e8e65f80d323764
    In the screenshot Cube , Cube 1 & Cube 2 are in the editable phase. I need to revert them to a normal object.
    Thank you,
    – David
    Brian Jones replied 10 years, 10 months ago 3 Members · 2 Replies
  • Paul Esteves
    October 25, 2015 at 3:45 am
    Unfortunately, you can “undo,” but other than undo, as far as I know you can’t change an editable object back.
  • Brian Jones
    October 25, 2015 at 4:40 am
    Pose Morph tag can work with editable objects (wouldn’t be any good otherwise). You were probably doing a Parameter morph just do a new set of poses with something that will work for what you are doing with the editable object (maybe scale, maybe Points – whatever works)
