Activity Forums Adobe Premiere Pro Beginner question-combining DSLR and Panasonic AVCHD
  • Beginner question-combining DSLR and Panasonic AVCHD
    Posted by Suzin Daly on June 17, 2015 at 6:29 pm
    I have two formats, DSLR [Nikon] and Panasonic 150 AVCHD, can I bring both onto the timeline without a problems? Both will be 1080 same fps. If so, when I set up, do I set up for the DSLR or AVCHD?
    Suzin Daly replied 11 years, 3 months ago 2 Members · 4 Replies
  • Daniel Waldron
    June 17, 2015 at 6:54 pm
    DSLR is not a format; the camera is most likely recording H.264. You should have no problem with H.264 and AVCHD files on a timeline.
  • Suzin Daly
    June 17, 2015 at 7:29 pm
    Thank you for the replay, I stand to be corrected, DSLR is not a format, wasn’t thinking it is H.264. Question, when I setting up for new project which do I set up for DSLR or AVCHD?
  • Daniel Waldron
    June 18, 2015 at 1:12 pm
    Whichever is the main camera if possible. It likely won’t make a difference, as the most important settings are frame size and frame rate and if they are both the same, you’re in good shape. I like to just drag a clip onto the “New Sequence” button and it automatically creates a sequence with the best settings.
  • Suzin Daly
    June 18, 2015 at 2:52 pm
    Thank you Daniel Waldron makes sense.
    Sz
