Activity Forums Adobe After Effects Expressions BEAM point tracking dilema
  • BEAM point tracking dilema
    Posted by Ken West on November 3, 2019 at 6:54 pm
    Hey all,
    Having an issue on what should be pretty straight forward.
    I want to joint 2 circle shape layers with a beam. These 2 circle shape layes are tracked (x,y) to individual trackers (nulls). Another method I have tried is applying the position track to the circle shape layes, which are then offset slightly with anchor point. Works great up to this point.
    Then, on a new layer, I set a beam effect, and the goal is to having beam starting point follow one shape, and end point follow the other. If I Beam>Position>Pickwhip the Pos of a circle, it follows the position perfectly, but the issue is, I have the circle slightly offset with anchor point. I want the Beam to follow where the circle is now, not its position.
    If I Beam>Position>Pickwhip the circle itself, I get error Öbject of typer Layer found where a Number, Array, Or Porperty is needed”
    Does anyone know a fix or workaround?
    Thanks in advance.
    Ken West replied 6 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
