Beam or Particle?
So, I somehow found a beam expression that does what i’m sorta trying to look for which is essentially something along these lines:
Sample1:
https://youtu.be/SCdAdihp9Os
Sample 2:
https://youtu.be/pZyCHYt2r-UExpression used:
rate=5.63;my_time=time%rate;
my_time=linear(my_time,2,rate,1,100);[my_time]
which resulted in this:
Now, before I move forward with trying to randomize this manually, a couple of questions:
1. Is there a faster way to do this with the particle effect instead of me copy pasting these layers and randomizing the stats of each one to look more fluid?
2. Should I stick to expressions like this because I have yet to see a tutorial on stuff like this(I ask because I know next to nothing about expressions) specifically or manually create it with photoshop and create frame by frames or even flash?
3. Lastly, I want something even as simple as the orange looking one, but something I can add variety on easily and randomize when necessary and ultimately emphasize the gradient whether it be via the blocky or more refined look. The colors I can figure out though. Any tips would be a godsend!Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
