Activity Forums Boris FX Particle Illusion Beam Me Up Scottie
  • Beam Me Up Scottie
    Posted by Louistr1 on August 10, 2007 at 12:55 am
    I must be doing something wrong. When I save my sample it doesn’t save the video in full..What’s that black section? How doe’s one save the effects created in particle illusion so they can bring them in after effects 7.0
    Here is a sample of what I get:
    Thanks guys!
    Louistr1 replied 19 years ago 2 Members · 4 Replies
  • Louistr1
    August 10, 2007 at 6:43 am
    Never mind, got it to work! Didn’t realize there was a pllusion render application that had to be used with the the file you create your effects with once you finished with the project.
    Thought it was all in one application.
    Thanks for the “too tour”
    Off to be cloned!
  • Alan Lorence
    August 10, 2007 at 3:24 pm
    You’re not required to use pIRender, only when the output res you want is larger than what you can fit on your monitor.
    You just need to make sure that your stage window is large enough at 100% zoom to fit the output size you want.
    Alan.
    http://www.wondertouch.com
  • Louistr1
    August 10, 2007 at 6:25 pm
    But it seems on my Mac running 10.4, if I wanted to get the video to load and save in quicktime enclosed with all the illusions in it’s original size it was imported in the only solution was that application.
    Will try what you suggest when I get home and see what happens…
    All in all, the pIRender did what the red button was supposed to do all at one click.
    It would be cool if there was a Stargate Transporter tutorial here too
  • Louistr1
    August 14, 2007 at 3:01 am
    It worked! Thanks!
    Always Trust The Voice Within
