Activity Forums Adobe After Effects Expressions Beam connecting nodes not working with DOF
  • Beam connecting nodes not working with DOF
    Posted by Lev on April 22, 2006 at 11:11 am
    Hi people,
    I’ve got a problem where several layers have been connected using the old “beam” effect trick to draw a line from the center of one layer to the center of another. The two nodes are in 3D space and the beam is on a 2D layer. The expression used is:
    targetLayer=thisComp.layer(““);
    targetLayer.toComp(targetLayer.anchorPoint);
    which I found here on the cow (thanks). This works brillantly. So off I go setting up tons of nodes. Now comes the part where I want to animate the camera in and around these nodes. Turns out the width of the beam doesn’t change as it gets further away, which is a bugger, but I can deal with that.
    Then, I turn on DOF and because the beams aren’t 3D layers, they don’t get blurred like the nodes they are connecting. ARGH!!! The DOF is a necessity due to the style of the piece.
    Is there anyway I can cheat this and still get the beam’s to honour the DOF by forcing them into 3D space somehow but still keep the connections?
    Any help would be appreciated!
    Lev
    Lev replied 20 years, 5 months ago 4 Members · 5 Replies
  • Mylenium
    April 22, 2006 at 11:40 am
    Nope, not this way. You’d have to use real 3D solids. If you look at my tutorials here at the COW (Sun, Spreading World Map), you will find the basic math (in 2D), all you need to do is take it to the 3rd dimension.
    Mylenium
    [Pour Myl
  • Alexxx
    April 22, 2006 at 1:35 pm
    Thanks for that. It’s helping me heaps. Only thing I’m now stuck on is getting the TRUE position of a layer that is parented to a null. The .position reference doesn’t seem to pull the absolute position of a layer after it’s parenting. Is there a way to get this. You see, all these nodes are also being rotated inside a NULL so all the positions are relative to the NULL at the top of the stack.
    Great tutorial, though!
    Cheers
    Alex
    http://www.lightdrop.com.au
  • Lev
    April 22, 2006 at 1:38 pm
    Heh oops…posted on a collegues PC where I was trying this. So ignore the confusion 😉
  • Dan Ebberts
    April 22, 2006 at 4:28 pm
    The expression from your first post should work, except use toWorld() instead of toComp():
    targetLayer=thisComp.layer(“”);
    targetLayer.toWorld(targetLayer.anchorPoint);
    Dan
  • Lev
    April 23, 2006 at 5:53 am
    That’s the ticket! Thanks Dan.
