Activity › Forums › Adobe Encore DVD › BD-Rs only in 1280×720???
  • BD-Rs only in 1280×720???
    Posted by Peter Parker on November 23, 2008 at 6:58 pm
    Oh hai 🙂
    first sorry for my bad english 🙂
    Well i have an encoding problem. I wanna create a BD-R from some rendered 1080p footage (25fps). Everytime i import the renderd quicktime (animationcodec) as an asset in encore it makes a timeline in 720p no matter if i choose 25p oder 50i for the transcode settings – really wired 8-o
    So i thought to leave encore and doing the encoding in premiere but the result is always the same. i’m getting a 720p file 🙁
    Next i did the encoding in TMPG and Quicktime – both are working fine but the Output (m2t and mv4) can’t be importet in encore without transcoding AGAIN! NOW THIS is totaly strange – because i thought Bluray is h.264 OR Mpeg-2. Hmmm…. to you guys have any tips for me?
    Thanks!!!
    Lucas Fazzary replied 17 years, 10 months ago 3 Members · 2 Replies
  • Jeff Bellune
    November 24, 2008 at 12:40 am
    If I’m not mistaken, 1080p/25 isn’t part of the Blu-ray spec. It’s not a legal BRD file.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Lucas Fazzary
    November 26, 2008 at 6:19 pm
    Here are the options for BD
    BD Video Type Frame Rate Codec Available
    Frame Size 1920 x 1080 16:9 Ratio
    HD 1080 24p 23.976 progressive MPEG-2, AVC, VC-1
    HD 1080 60i 29.97 interlaced MPEG-2, AVC, VC-1
    HD 1080 50i 25 interlaced MPEG-2, AVC, VC-1
    Frame Size 1440 x 1080 16:9 Ratio
    HD 1080 24p 23.976 progressive AVC, VC-1
    HD 1080 60i 29.97 interlaced AVC, VC-1
    HD 1080 50i 25 interlaced AVC, VC-1
    Frame Size 1280 x 720 16:9 Ratio
    HD 720 24p 24 progressive MPEG-2, AVC, VC-1
    HD 720 60p 59.94 progressive MPEG-2, AVC, VC-1
    HD 720 50p 50 progressive MPEG-2, AVC, VC-1
    Frame Size 720 x 480 16:9 Ratio or 4:3 Ratio
    SD 480 60i 29.97 interlaced MPEG-2, AVC, VC-1
    Frame Size 720 x 576 16:9 Ratio or 4:3 Ratio
    SD 576 50i 25 interlaced MPEG-2, AVC, VC-1
