Activity Forums Boris FX BCC6 Extrude Spline
  • BCC6 Extrude Spline
    Posted by Seannon O’daniel on April 24, 2009 at 8:31 pm
    Maybe I have missed it but is there a way use this filter on a compound path from illustrator.
    They import into AE as multiple masks.
    Extruded Spline seems to only support a single path per application of the filter.
    In this case I want to punch holes out of a extruded circle.
    Seannon O’daniel replied 17 years, 4 months ago 2 Members · 15 Replies
  • 15 Replies
  • Peter Mcauley
    April 24, 2009 at 9:17 pm
    The answer is yes.
    To do this, create the compound path object in Adobe Illustrator, then save it as an Illustrator eps file. This can be opened within the BCC Extruded EPS filter in AE, preserving the hole in the center of the object.
    I hope this helps,
    Peter.
  • Seannon O’daniel
    April 24, 2009 at 9:23 pm
    Maybe I am missing a step or a plug-in.
    I have a BCC Extruded Spline but no EPS. I think that is what you are talking about.
    How do I open the EPS file with it?
    I have tried to past the path from illustrator but still comes across as a compound path.
  • Seannon O’daniel
    April 24, 2009 at 9:43 pm
    Make that….
    I have tried to paste the path from illustrator but still comes across as a compound path (as multiple masks in difference mode).
  • Peter Mcauley
    April 24, 2009 at 10:35 pm
    I think the problem is that you need to download the latest version of BCC 6. We made an update that includes a couple of new filters – BCC Swish Pan and BCC Extruded EPS. It’s the Extruded EPS filter that you need to extrude the Illustrator EPS file with compound paths.
    You can download the free update to the latest version here:
    https://www.borisfx.com/downloads
    Cheers,
    Peter.
  • Seannon O’daniel
    April 24, 2009 at 11:33 pm
    Just now downloaded the latest Mac version of the trial.
    No SwishPan was installed and no Extrude EPS.
    Is there another place to get the latest version that I am missing?
  • Peter Mcauley
    April 24, 2009 at 11:52 pm
    That’s rather odd alright – I would have expected the filters to exist for you just as they do for me. Hmmm … why don’t you send me your set up info (platform/os version etc) which might help me understand why they don’t show up for you as they do for me.
    Did you uninstall before you reinstalled the update?
    Cheers,
    Peter.
  • Seannon O’daniel
    April 24, 2009 at 11:56 pm
    I am on a MacBook Pro, 2.6GHz, 4GB RAM, 500GB HD, nvidia 8600m GT with 256MB VRAM.
    Mac OS 10.5.6
    After Effects 9.0.1 (as part of Master Collection CS4)
    No I did not uninstall. I did check the CS4 Media Core folder and the AE Plug-Ins and there is nothing new
    Also the trial installer is dated Feb 28th, 2009
  • Seannon O’daniel
    April 25, 2009 at 12:03 am
    Sorry meant Feb 18th, 2009
  • Seannon O’daniel
    April 25, 2009 at 12:22 am
    Also just tried uninstall and reinstalling and even downloaded it again.
    Still Feb 18th, no Extrude EPS, No SwishPan.
    Do you have another installer for the AE plug-in I can download somewhere?
  • Peter Mcauley
    April 25, 2009 at 1:43 am
    I’m checking with engineering on this – you should have both filters. Thanks for providing the system specs and I’ll be back in touch as soon as the release engineer on this project has a chance to get back to me.
    Cheers,
    Peter.
