Activity › Forums › Avid Media Composer › BCC5 on Avid V4
BCC5 on Avid V4
Posted by Graham Saywell on March 19, 2010 at 8:22 pmRecently upgrade from MC V3.12 to V4. Borris BCC5 seem to have some issues and I get some error messages. Do I have to upgrade to BCC6 to run on MC4?
Matt Mullen replied 16 years, 5 months ago 2 Members · 12 Replies -
Matt Mullen
March 19, 2010 at 8:35 pmThat’s what is supported. What are the error messages and when do you get them?
Graham Saywell
March 19, 2010 at 9:04 pmHappens when I apply any BCC5 plugin to the time line.
Message as follows: Exception: AParamiter: Unique Indentifier to Parameter ID- Unable to convert UID to Param ID -
Matt Mullen
March 21, 2010 at 2:52 amIs this an error pop up or a message in the record monitor?
Can I get your full system specs an hardware if any?
Graham Saywell
March 21, 2010 at 12:20 pmHey Mathew.
First off. Thanks for helping me out with this. I have a query into Boris as well but they aren’t so “Johnny on the spot” geting back.
The error is a pop up.
This system was running V3.12 with Borris 5 np. It was a bundled version that came with the V3.05 upgrade.I’m currently running this on a MacBook Pro dual core intel@ 2.6ghz w 4gigs or ram and an SDI Mojo.
My other plugins, Moving Picture and Magic Bullet don’t seem to be effected.
Matt Mullen
March 21, 2010 at 4:33 pmGraham,
I am Boris Support ;). It look like you sent the query after everyone was gone for the weekend.
I’ve seen a similar error before. Can you try pulling the SDI Mojo off the system and see if you have the same result?
Is this on all projects/ Project types/Avid users/ all BCC filters?
Graham Saywell
March 21, 2010 at 8:27 pmActually I haven’t had the mojo hooked up since I installed v4.
Any other suggestions? -
Matt Mullen
March 21, 2010 at 8:40 pmI need to know if you are seeing this across all projects, avid users and BCC filters.
Can you start a new project and new user and bring in some test footage to see if the filter works?
Do you have other 3rd arty filters installed?
Also whats the exact version of MC you’re on? It looks like this was an issue at one point with MC 3 maybe it was in an early build of MC 4. Check out this thread:
https://community.avid.com/forums/t/71115.aspx?PageIndex=2
Graham Saywell
March 22, 2010 at 12:16 amMathew,
Wow, I really appreciate all the time you are putting in on this. I will do a “full work up” based on your questions tomorrow. I will need to copy some media over from my other Avid which is still running version 3.13 software. My current version is version 4.02. What I might try is to grab a sequence from the other machine with some boris plugins already in the time line and see what that does. I’ll get back to you tomorrow.
Thanks again
Graham Saywell
Graham Saywell
March 22, 2010 at 2:29 pmActually in the middle of an email conversation with Avid right now. I was not able to start MC with the mojo attached. Seems to be related to the other problem. I have uninstalled MC and will delete Boris off the system as well and start from scratch.
Thanks again, I’ll keep you posted.
g
