Activity › Forums › Boris FX › BCC Optical Stabilizer 6.0.7.2 and PAL interlaced HD
  • BCC Optical Stabilizer 6.0.7.2 and PAL interlaced HD
    Posted by Yuri Radaev on April 30, 2010 at 2:08 pm
    Hi! I’m trying BCC OS (default settings) with ProRes 1440×1080@50i and get jerky result. To eliminate this, i can to use De-interlace filter – it’s working, but i lost 50i video. De-interlaced video is not acceptable in my case, so what i can do? Maybe you can help me?
    Matt Mullen replied 16 years, 4 months ago 2 Members · 14 Replies
  • 14 Replies
  • Matt Mullen
    April 30, 2010 at 2:32 pm
    Yuri,
    Where exactly are you running into the problem…with Optical Stabilizer?
    What does the footage/problem look like?
  • Yuri Radaev
    April 30, 2010 at 3:06 pm
    Sorry, i forgot 🙁 I am using Final Cut 7.0.2 and BCC OS 6.0.7.2. My video is HD video 16:9 1440×1080@50i ProRes
    The problem i have looks like a small jitter. Only one field are stabilized or something like this… If i’ll apply deinterlace after BCC OS – jitter will disappear and stabilizer will work fine. But i need both fields, deinterlace is not acceptable 🙁
  • Matt Mullen
    April 30, 2010 at 4:02 pm
    Could you possibly send me a short clip to look at.
    My e-mail is mattm@borisfx.com
    You could use yousendit.com to send the clip.
  • Yuri Radaev
    April 30, 2010 at 5:27 pm
    I have send it!
  • Matt Mullen
    April 30, 2010 at 7:30 pm
    Yuri,
    I rendered as is and it looks good.
    I then rendered without the deinterlace filter and it still looks good.
    I see no flicker or interlacing in FCP
    Where are you seeing the problem.
    Do you have an output file or screen shot that shows the problem?
  • Yuri Radaev
    April 30, 2010 at 8:21 pm
    Did you try another field order in deinterlace filter?
    Interlacing MUST be visible with HQ timeline settings and 100% canvas size. You see no interlacing??
    I can record screencast but it takes time…
  • Matt Mullen
    May 1, 2010 at 12:14 am
    if you can see the problem parked on a frame you can send me a screen shot.
    If not a video would be nice.
    I took off the deinterlace because I thought you didn’t want to use it and it would give me a chance to see the problem.
    Let me know if that is correct.
  • Yuri Radaev
    May 1, 2010 at 8:29 am
    I has sent video example on your mail.
  • Matt Mullen
    May 3, 2010 at 4:29 pm
    Yuri,
    I see the “interlacing” issue even with no filters applied.
  • Yuri Radaev
    May 3, 2010 at 7:23 pm
    Hi Matthew!
    If FCP show’s interlacing it is normal. FCP must show both fields in canvas with 100% frame size and HQ timeline. If canvas sets up to fit frame (or timeline is medium/draft)- fields not showing.
    The problem appears on interlaced footage because BCC OS process only one field. If i take progressive footage – stabilizer works fine. Can you ask yours software engineer – BCC process both field or single? Maybe you can check it? Thanks!
