Activity Forums VEGAS Pro BCC Match Move problem
  • BCC Match Move problem
    Posted by Grzegorz Kwiatkowski on May 26, 2013 at 5:06 am
    I want to track motion using bcc match move in several moments of 25 minute project. I want to place text on tracked pixels. Everything works great when events are at the beginning of the project (I am doing it step by step according to JRofrano’s tutorial). The problem starts when I want to track motion later, for example in 15 minute. Then track on fly doesnt work and I get error message. I know there is Start Tracking parameter value but it’s very cumbersome to use it.
    I am applying Match Move on track level. Maybe this is the reason? Is there any option to do it on event level? Maybe there is a different way?
    Grzegorz Kwiatkowski replied 13 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    May 26, 2013 at 1:21 pm
    [Grzegorz Kwiatkowski] “I am applying Match Move on track level. Maybe this is the reason? Is there any option to do it on event level? Maybe there is a different way?”
    The only way to make this work is in a new project. Then drop that project at the 15 minute mark in your existing project as a nest project. This is the same as using PreComp in After Effects. You should always work this way when using special effects that composite tracks for only a portion of your project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Grzegorz Kwiatkowski
    May 27, 2013 at 6:14 am
    Thanks John.
    But anyway it would be much less troublesome if this feature worked on effect level.
