BCC 9 Extruded EPS = black screen
Posted by Frank Stevn on September 10, 2014 at 2:47 pmI use BCC9 in Vegas Pro 13.
I add Extruded EPS fx to an empty event and select the AI file. Then I only get a black screen with a white text showing the path to the selected ai file.
Any idea?
Frank Stevn replied 11 years, 11 months ago 3 Members · 4 Replies -
Steve Rhoden
September 10, 2014 at 4:26 pmCheck your OpenGl and GPU settings….
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Frank Stevn
September 10, 2014 at 9:41 pmThank you Steve.
My PC has two display adapters, both AMD Radeon HD 5700 Series.
It makes no difference if I change ‘GPU acceleration of video processing’ to -None- or -Advanced Micro devices, Inc-, in ‘Preferences/Video’; either way I still get the black screen.
Is there a different place to change the OpenGl and GPU settings?
John Rofrano
September 12, 2014 at 11:31 amIt could be a problem with the AI file. It must be saved in Illustrator 8 format. Nothing newer will work! Post it here so we can take a look if you already saved it as an Illustrator 8 file and want us to check it out.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Frank Stevn
September 12, 2014 at 1:08 pmThanks John.
I am working with AI CS9. Fallowing your advice I saved the file as AI8 (*.ai and *.eps) and still doesn’t work
