Activity › Forums › Apple Final Cut Pro Legacy › BCC 4 and FCP 5.1.4
BCC 4 and FCP 5.1.4
Posted by Paul Nevison on May 21, 2007 at 4:58 pmhey so
i just upgraded our machines between projects to 10.4.9. FCP 5.1.4
now our BCC 4 plugins will not display the controls in the filters tab, this even after following the whole caps lock on/off steps
anyone else having issues after upgrading?
thanks
ps with the new cow interface where is the link to update your profile?
G5 DP 2.0 (Power PC)
4.0G RAM
OS 10.4.8
QT 7.1.3
FCP 5.1.2
BMD Decklink Extreme 6.0
PAL LandLee Berger replied 19 years, 4 months ago 3 Members · 5 Replies -
Walter Biscardi
May 21, 2007 at 5:44 pm[paulos] ”
i just upgraded our machines between projects to 10.4.9. FCP 5.1.4now our BCC 4 plugins will not display the controls in the filters tab, this even after following the whole caps lock on/off steps
anyone else having issues after upgrading?”
Go to the Boris website. This is a known issue and you need to run a script to re-install the BCC4 filters in FCP 5.1.4
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Paul Nevison
May 21, 2007 at 5:53 pmthanks Walter,
I had already looked on the boris site, is the script you are referring to the one marked for Intel machines?
we are all power pc here, does that make any difference?
4.0G RAM
OS 10.4.8
QT 7.1.3
FCP 5.1.2
PAL Land -
Lee Berger
May 21, 2007 at 8:23 pmDownload the release notes and carefully follow the directions.
https://www.borisfx.com/download_files/BCC4FCP5.1%20patch.pdf
Most of the fix deals with deleting the FCP ObjectCache and Profs Cache. The script Walter refers to pertains to problems between BCC4 and Calligraphy on Intel Macs. Since your running a Power PC it probably doesn’t apply.
By the way I’ve found that you may have to delete the cache files on more than one occasion.Lee Berger
http://www.leebergermedia.com -
Paul Nevison
May 22, 2007 at 8:52 amI’ve had and been using the workaround for the known issues since 5.1.2 and have been following the capslock and trash preferences instructions to the letter.
since going to 5.1.4 now the capslock and trash prefs instructions are having no effect, with boris either putting a black cross through the clip or not showing the controls in the filter tab.
I’m puzzled as to why this is happening and asking whether 5.1.4 created a new set of issues for BCC and FCP
4.0G RAM
OS 10.4.8
QT 7.1.3
FCP 5.1.2
PAL Land -
Lee Berger
May 22, 2007 at 8:56 amPerhaps you should post this on the BorisFX forum where someone from Boris often replies, or contact Boris directly. They have excellent support.
Lee Berger
