Activity › Forums › Apple Final Cut Pro Legacy › BCC 3 does not work with FCP 5.1.2
Posted by Itamar Kool on October 22, 2006 at 1:21 pmJust upgraded from 5.0.4 to 5.1.2 and now my Boris Continuum 3 filters won’t work anymore. Saw that there is a patch for BCC 4 but not for BCC 3. What’s the solution??
Kool En De Anderen
dual 1.8 gig G5/Mac OS 10.4.6/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 7 Pro
http://www.koolendeanderen.nlSteve Eisen replied 19 years, 11 months ago 6 Members · 9 Replies -
Jerry Hofmann
October 22, 2006 at 2:29 pmUpgrade?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Steve Eisen
October 22, 2006 at 2:36 pmBCC 3 works on my system. You need to follow Boris’ instructions very carefully.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Lee Berger
October 22, 2006 at 3:21 pmI wish Boris would fix that. It seems as if every time I go to use BCC or Red 4 plugins I have to go through the trashing and caps lock rigamarole. It’s too easy to cause a problem if you don’t follow the instructions for applying a filter (ie you can’t have the filter tab open when you apply).
Michael Alberts
October 22, 2006 at 3:41 pmAnother bug I found the other day relates to BCC4’s Chroma Key filter. You can’t have the playback setting on “Unlimited RT”. You have to set it to “Safe RT” for the filter to work. Otherwise you get a black background instead of your b.g. layer.
Michael Alberts
Ambidextrous Productions, Inc. -
Walter Biscardi
October 22, 2006 at 3:56 pm[Steve Eisen] “BCC 3 works on my system. You need to follow Boris’ instructions very carefully.”
Yeah, especially the part about keeping Caps Lock on the first time you launch FCP after the install.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Itamar Kool
October 22, 2006 at 4:17 pmI took the BCC plug ins folder out of the FCP plug ins folder. Won’t be using BCC 3 in FCP until they really fix this
Kool En De Anderen
http://www.koolendeanderen.nl -
Jerry Hofmann
October 22, 2006 at 10:38 pmI thought this was broken for a bit. It’s all fixed now?
Jerry
Itamar Kool
October 23, 2006 at 9:31 amI don’t understand what you mean. The whole thing between BCC 3 and FCP 5.1.2 looks so uncertain to me that I took out the whole BBC 3 plug ins folder from FCP. If I need BCC, I’ll use it in After Effects.
Kool En De Anderen
dual 1.8 gig G5/Mac OS 10.4.8/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.1.2/AE 7 Pro
Steve Eisen
October 23, 2006 at 12:59 pmYes I DO have to keep pressing te CAPS lock to open FCP 5.1.2
Steve Eisen
Director-At-Large
