Activity › Forums › Sony Cameras › Battery Light on Stand
  • Battery Light on Stand
    Posted by Bill Evelyn on May 25, 2010 at 1:25 am
    Hey, again, everyone
    My shoot is coming fast and furious and I’m using a kit that I don’t usually use…so I’ve been pepperin’ the Cow with questions. Here’s another.
    I’m shooting with an EX-3, and as I can’t find a camera-mounted light to run off the camera’s IDX Elite battery, I’m wondering if there’s a light that will run off the same battery but not mounted to the camera…essentially, a lamp on a stand, powered by the battery sitting on the floor.
    I used to do this in a pinch with those flat Sony BP90 batteries and Mini-Frezzi or Lowel Pro “sun guns” so the light wasn’t right on the camera.
    Does such an animal exist? Make and model would be great!
    Thank you, as always…
    Ronnie Martin replied 16 years, 4 months ago 2 Members · 1 Reply
  • Ronnie Martin
    May 25, 2010 at 7:11 pm
    I use a power tap from IDX that allows me to run a on camera light or one on a stand separate from the camera battery on the EX-3. I have a shoulder brace by Olof@WestsideAV.com and they included a power plug that would work for a light. I am sure you can find a power tap from IDX…. Just plug it in to the power connection on the IDX and then power you light with it. Also theere is a power tap for 12 volt lead acid batteries like the “Again& Again” 12 volt battery that will allow you to run a light.
    Hope this helps
    Ronnie Martin
    https://www.ramtv.tv
    Ronnie Martin
    Kato Video Productions
    http://www.dirtracingvideo.com
