Activity › Forums › Apple Final Cut Pro Legacy › Batching MP3’s, 44khz Aiff’s, etc.. to 48khz Aiff. What application do you use?
  • Batching MP3’s, 44khz Aiff’s, etc.. to 48khz Aiff. What application do you use?
    Posted by Alexander Serpico on January 26, 2006 at 6:11 pm
    What does everyone use to batch convert audio files?
    We used to use mAC3dec, at it was great!
    But now it is incompatible with Tiger, and no one has updated the program.
    Looking at QTAmateur, seems just OK but some files it will not convert for no apparent reason.
    Where i work the editor’s assistants MUST prep all audio to AIFF @ 48khz prior to giving it to the editor.
    yes, i know Compressor 2 is great for this… BUT we want to be able to do this on any and all of our assistant stations as well….
    Really the batch export ability should be available in Quicktime Pro.
    Dave Mac replied 20 years, 8 months ago 6 Members · 5 Replies
  • Ben Oliver
    January 26, 2006 at 7:13 pm
    dont know if this helps, but you can export multiple clips in QTpro, just open them all up, and export each of them. it will do quite a bit.
    works great.
  • Jeremy Doyle
    January 26, 2006 at 7:30 pm
    Why not use itunes? Just set up a playlist as your batch.
  • Walter Biscardi
    January 26, 2006 at 8:16 pm
    [ben] “but you can export multiple clips in QTpro,”
    I do this all the time for AIFF files and CD Audio files, but QT Pro doesn’t export mp3’s.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Mark Maness
    January 26, 2006 at 9:42 pm
    I found a program called Sound Grinder 2.5 to do just what you are doing. It works wonderfully. Very customizeable and very reasonably priced at $39 US. Give it a look. I love it.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Dave Mac
    January 28, 2006 at 2:30 am
    You may want to use Final Cut Pro itself!
    I answered this same question in November last year. Here’s the post:
    Use FCP to Batch Convert AIFF/MP3 files to 48kHZ AIFFs
    Cheers,
    Dave
