Activity Forums VEGAS Pro Batch Turn Regions into Sub-Clips. (from one track-pair) (Vegas Pro 13)
  • Batch Turn Regions into Sub-Clips. (from one track-pair) (Vegas Pro 13)
    Posted by Christine Neuvil on January 25, 2018 at 12:08 pm
    I have an audio and video track starting with file A, followed by file B, followed by file C. I have 20 regions, spread over all three files. Can I batch convert the regions into sub-clips? How?
    If part of file A overlapped part of file B, could a region at that location become a sub-clip?
    (I read on https://forums.creativecow.net/thread/24/992277 that we can’t turn regions into subclips if the region contains multiple source files, but that left me with the above questions.)
    If the audio and video track were from different source files, a sub-clip could not be created, right?
    Using Vegas Pro 13 on Windows 10
    Christine Neuvil replied 7 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    January 25, 2018 at 3:40 pm
    [Christine Neuvil] “If the audio and video track were from different source files, a sub-clip could not be created, right?”
    That’s correct.
    A Media File = A Clip.
    A Subclip is a Sub-Media file not Multiple Media files. So a sub-clip must be a subset of one media file (i.e., smaller than a clip).
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Christine Neuvil
    January 27, 2018 at 12:56 pm
    Can anyone help with my main questions (the first two)?
  • John Rofrano
    January 28, 2018 at 12:18 am
    [Christine Neuvil] “I have an audio and video track starting with file A, followed by file B, followed by file C. I have 20 regions, spread over all three files. Can I batch convert the regions into sub-clips? How?”
    VASST Marker Editor can convert Regions to Subclips. Obviously if a region spans two files it cannot do the conversion because a sub clip can only be made from a single file. Unfortunately, you cannot buy it right now (we’re working on a new eCommercce solution) but if you send an email to our support email at vasst.com we will help you out.
    [Christine Neuvil] “If part of file A overlapped part of file B, could a region at that location become a sub-clip?”
    No, a subclip must be from one single file.
    ~jr
  • Paul Berk
    January 28, 2018 at 5:48 am
    [Christine Neuvil] “Can anyone help with my main questions (the first two)?”
    You could use “tools/scripting/batch render” to batch render the regions to MXF files (these are essentially lossless). This is not the same as sub-clips, but it might provide a solution.
  • John Rofrano
    January 28, 2018 at 1:53 pm
    [Paul Berk] “This is not the same as sub-clips, but it might provide a solution.”
    Actually, that’s the only solution if you need to combine content from two different files. Good suggestion. Maybe make subclips for everything that is from a single file and MXF for all of the combined files.
    ~jr
  • Christine Neuvil
    January 8, 2019 at 10:37 am
    A much-belated Thanks.
    Alas, it’s only virtually loss-less if I choose the right Render Template(s).
    Why can’t Vegas provide an option: “Match Render Template to Original”?
    My current project’s timeline has videos from various sources, each with different formats/specs. I think the “Match Render Template to Original” button should render each region with its source’s original format/specs.
    Can that suggestion go to Magix staff and/or non-Magix coders?
    Thanks again.
  • Wayne Waag
    January 9, 2019 at 7:13 am
    The AviDub tool in Happy Otter Scripts https://tools4vegas.com/ already does this. Here is a screenshot of the UI.
    You have the option of rendering events, the selection loop, regions or the entire project. If you choose to render selected events from Vegas using the DebugMode FrameServer, project settings are changed to match media settings for each event. That event can then be transcoded into a high bitrate x264 format or a lossless format such as MagicYUV or UtVideo. The rendered events are then returned to the timeline as an added take to the original event or to a new track.
    Although AviDub was originally designed to enable the use of external filters from Avisynth and VirtualDub, it can also be used for simple transcoding.
    wwaag
  • Christine Neuvil
    January 9, 2019 at 7:35 pm
    Thanks Wayne! I like the idea of Happy Otter Scripts – a bridge between Vegas and open source tools. I’ll try it, hopefully this month.
