Activity Forums Adobe After Effects Batch – Save Frame As
  • Batch – Save Frame As
    Posted by Ryan John on September 2, 2013 at 5:11 pm
    Is there a way to batch render “Save Frame As”?
    Every clip I produce I need a thumbnail like image to go with it. Usually I just hit “Save Frame As” before rendering.
    In this instance I need to do this for several hundred clips. I know I can drag and drop all the comps to the render queue to batch produce the clips, now I need to find a way to batch render the thumbnails too?
    Jared Rowe replied 10 years, 7 months ago 3 Members · 2 Replies
  • Erik Waluska
    September 2, 2013 at 7:47 pm
    There’s a script that will render still frames at every marker in the timeline – that might be your best bet,
    Render Frame at Markers script
    Also, in case you don’t already know, the shortcut for “save frame as” is ctrl/cmd + shift + s.
    You can set the default file type in Edit>Templates>Output Module>Frame Default.
    Erik Waluska
    EAWmedia
  • Jared Rowe
    February 14, 2016 at 6:46 am
    Hey Ryan what did you end up learning here? I am in the same boat now and see that you dealt with this 2 years ago. What was your solution to batch the thumbnails?
