Activity › Forums › Adobe After Effects › Batch rendering same comp with different text
  • Batch rendering same comp with different text
    Posted by Nicola Cornolti on October 27, 2021 at 11:41 pm
    I often find myself needing to render a comp multiple times just with a slight change, for example a lower third with 30 or so names to manually write each time. I always think there has to be a better way to do it, perhaps with scripts.
    What I need is just a way to take a list and automatically duplicating the comp and substitute a sample text
    Eric Santiago replied 4 years, 11 months ago 2 Members · 1 Reply
  • Eric Santiago
    October 28, 2021 at 1:20 pm
    You would need to set it up prior but have been using Text2SpreadSheet of late and it’s a time saver.
