batch rendering queue in Vegas 10
Posted by Grzegorz Kwiatkowski on November 30, 2010 at 2:05 amHi guys,
is it possible to set a batch rendering list in Vegas 10 (as it’s possible in After Effects). It would very useful at least if possible within one project.
thanks
John Rofrano replied 15 years, 9 months ago 4 Members · 6 Replies -
Mike Kujbida
November 30, 2010 at 2:33 amIf you’re using Pro 10, it has a built-in batch render script that should do what you want.
If you’re using one of the Movie Studio versions, sorry but scripting is not a supported feature.
Aleksey Tarasov
November 30, 2010 at 4:31 amFor advanced batch rendering you can try Transcoder from Vegasaur toolkit. You can freely use it for 30 days and see if it suits your needs.
p.s. Also for the Pro version
November 30, 2010 at 4:58 amI’ve checked it out and it’s indeed there. Just a pity you can’t batch render multiple projects with one Vegas active.
Mike Kujbida
November 30, 2010 at 11:40 am[Grzegorz Kwiatkowski] “Just a pity you can’t batch render multiple projects with one Vegas active.”
Open multiple instances of Vegas and render as desired.
Veggie Toolkit is another program to look into as it supports that feature. -
John Rofrano
November 30, 2010 at 2:40 pmThere are also powerful batch render functions in VASST Ultimate S Pro on the Render tab. Also Vegas Pro Production Assistant can perform batch processing and rendering of multiple projects.
~jr
http://www.johnrofrano.com
http://www.vasst.com
