Activity Forums VEGAS Pro batch render in movie studio hd platinum 10
  • batch render in movie studio hd platinum 10
    Posted by Mike Mathewson on August 24, 2010 at 9:05 pm
    New to the forum and to Vegas, so please pardon my ignorance…
    I have a bunch of clips that I want to render as .mov files. Right now, it looks like it will take about 20 minutes to render a file that is about 5 minutes in length.
    Is there a way to pull multiple clips into the timeline, edit them, and then render them all at once, rather that having to wait for each clip to render and then starting on the next one? I need all the clips saved as separate files.
    Michael
    Mike Kujbida replied 16 years, 1 month ago 3 Members · 2 Replies
  • Roy Van der westen
    August 24, 2010 at 9:26 pm
    Yes, it also was my problem when I first started out. You need to drag those yellow arrows to select all of your footage that you want to render. If you dont want to do this you can easily uncheck the checkbox in the render menu. (Images below):
    -RvdW
    If you have a problem, if no one else can help, and if you can find me, maybe you can hire me
  • Mike Kujbida
    August 25, 2010 at 1:58 am
    Unfortunately Movie Studio doesn’t support scripting like Vegas Pro does.
    This is a feature necessary to do what you want to do.
    What you can try is to open multiple copies of Movie Studio and start them all rendering.
