Activity Forums VEGAS Pro Batch render code modification?
  • Batch render code modification?
    Posted by Oleg Merkuryev on October 20, 2014 at 8:06 am
    I took a standard batch render code… Already figured out how to batch regions with names, but I need couple more tweaks:
    1) How to avoid calling out BatchRenderDialog? Can a script proceed directly to rendering regions(!) as wav 44.1/24?
    2) That’s the piece of code I use for naming batched files:
    fileName = Path.GetFileNameWithoutExtension(projectPath);
    String regionFilename = String.Format("{0}{1}{2}",
    filename,
    regionIndex + 1,
    renderItem.Extension);
    I need to alter next:
    a) Put a text for filename, say word “Legato”
    b) The name of my project is a digit, say “86”. The project has one wav file with 12 regions. I’d like to have rendered files named like this:
    Legato_1_85 (1 stands for region number, 85 is the project name minus 1)
    Legato_2_84
    Legato_3_83
    Legato_4_82 etc
    Legato_12_74
    Would really appreciate the help! Thanks!
    Oleg Merkuryev replied 11 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
