Activity Forums Audio Batch processing
  • Batch processing
    Posted by David Gruwier on December 23, 2011 at 2:32 am
    Does anybody know of an audio editor or DAW that supports both batch processing and VST plugins?
    I have 126 audio files that I need to process. Basically I just need something that will open all the files, run them through a couple of VST plugin effects and save them back with the original file name.
    Koffi alain Sessi replied 14 years, 8 months ago 3 Members · 2 Replies
  • Richard Crowley
    December 23, 2011 at 2:41 am
    I have found Adobe Audition to be very convenient for doing batch processing. I don’t have specific experience with using VST plugins with batch, however.
  • Koffi alain Sessi
    December 23, 2011 at 5:44 am
    Hello David
    IK Multimedia’s T-Racks 3 will do the trick. Just to make sure I was not off the mark, I loaded about 20 SFX files into it, used one of the presets, and just batch-processed all the files. It worked well. Other in-the-box mastering solutions such as Wavelab may also work. However, I can only speak for T-Racks 3. I hope this helps.
    Alain Koffi Sessi
    Sound Designer
