Activity › Forums › Apple Final Cut Pro Legacy › batch monitor quits unexpectedly
  • batch monitor quits unexpectedly
    Posted by Severe Scott on September 19, 2007 at 2:07 am
    exporting using compressor. batch monitor launches. finishes first audio track and quits unexpectedly. anyone experience this and how to fix?
    thank you
    Scott
    David Bogie replied 19 years ago 2 Members · 1 Reply
  • David Bogie
    September 19, 2007 at 2:36 pm
    Generally depends on your settings and the output format, information you have not provided.
    Do you get little yellow exclamation points in the interface anywhere? Often caused by trying to use setting sthat are incompatible with a your chosen format. WMV, for instance, is very picky and will crash or stop if you try to change aspect ratio, crop or scale the image.
    There is a Compressor forum at apple.com discussions. Very low traffic, just a bunch of complainers. We can offer little or no help because we just don’t know much about the application’s faults (except there’s a really long list of them) or how to fix them.
    bogiesan
