Activity › Forums › Compression Techniques › BAtch monitor keeps going up and won’t cancel
  • BAtch monitor keeps going up and won’t cancel
    Posted by Hilleke Doevendans on May 8, 2008 at 4:28 pm
    Hi there,
    I thought I’d try submitting a batch to compressor (3) from Final Cut yesterday. All went well until it reached the 7th clip, on which it froze. I say froze, but in actual fact, the time remaining just kept on climbing. Tried to cancel and it wouldn’t. Tried to submit other batches and it just ignored them. Quit Compressor and Batch monitor and when I re-opened them, it was still there, steadily climbing in time.
    I restarted and re-tried it, this time from a QT reference, so I could continue working in FCP. Again it got stuck on this clip, but was able to do others. So I gave up on that clip, restarted, and finished the rest. Today when i opened compressor, it had somehow found that clip again and was quietly trying to compress it. I can’t cancel it, it won’t go away if I restart it, I’ve deleted preferences, done disk repairs, and have tried re-installing. IT WON’T GO AWAY!!!!
    Any help would be muchly appreciated! It was almost up to 3 hours at one point. The clip duration is only 5 seconds! Help!!!
    2.5GHz PowerPC G5 | Mac OS X (10.3.9) | 4.5Gb DDR SDRAM
    Final Cut Pro HD 4.5 | DVD Studio Pro 3.0.2 | Compressor 1.2.1
    Adobe Photoshop CS | Adobe After Effects 6.5
    Mac Pro: Two 2.66 GHz Dual-Core Intel Xeon | 4GB RAM | ATI Radeon X1900 XT 512MB (2 x dual-link DVI)
    Studio 2 | Adobe Photoshop CS | Adobe After Effects 6.5
    Adam Eich replied 14 years, 5 months ago 11 Members · 19 Replies
  • 19 Replies
  • Daniel Low
    May 8, 2008 at 5:56 pm
    See the post directly under this one, it may help you solve this issue.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Hilleke Doevendans
    May 9, 2008 at 8:26 am
    Seen it. Tried it. Different problem.
    My clip isn’t actually compressing at all. The file is stuck at less than a third and try as I might I can’t cancel it. I can’t stop it. I can’t get rid of it by closing the program. I can’t even get rid of it by re-starting.
    I’ve tried re-installing, as that’s the only advice Apple gives, but have hit problems with that too. Please someone help!
    May 9, 2008 at 11:28 am
    Never mind. I’ve done a complete re-install and the clip finally seems to be gone.
    Lets hope the rogue clip doesn’t come back…
    September 24, 2008 at 8:40 am
    Months later and the problem has arisen again.
    I’ve exported some QT refs from FCP. Taken these into compressor. Left them going over night, only to come in in the morning and it’s still trying to compress the first clip and has been for 15 hours.
    I’ve compressed these same clips last week and only changed a few minor things (titles and such) and they only took about 20-30 minutes that time.
    I’ve tried closing Compressor and Batch Monitor. That doesn’t stop it. Restarting the Mac doesn’t stop it. And it seems to get stuck each time it tries to compress this clip.
    ANY HELP will be very much appreciated as this seems to keep popping up, and I can’t be re-installing the entire system every month!
    (The system this is happening on is running FC Studio 2, all with latest updates)
  • Daniel Low
    September 24, 2008 at 11:04 am
    I guess any support guy, including Apple support (and me!) would suggest that you need to update your OS, which is roughly three years out of date and they’d certainly tell you to get the latest version of compressor which is now on version 3.
    September 24, 2008 at 11:17 am
    Sorry I should have been clear about which system this problem is occurring on.
    The OS is 10.4.11, bought earlier this year. And the version of Compressor is 3.0.3.
    But thanks for your helpful tip anyway.
  • Daniel Low
    September 24, 2008 at 11:55 am
    If it’s getting stuck at a certain point in a certain clip/programme that would indicate a bit of ‘bad’ or unrecognised media. Does it stop at the same point in the same clip every time?
    February 13, 2009 at 6:03 pm
    Well, almost a year later, the same problem has cropped up again, and I still have no solution.
    Again, restarting won’t stop compressor from trying to compress this clip and the batch monitor keeps ticking away. I can get away with shutting down the computer and restarting it once or twice, but after 2 times that doesn’t help either. I’ve tried tricking compressor by changing the source folders name – this worked once, but now it seems to find the clip where-ever it is.
    Surely someone else must have come across this problem and have some kind of solution??? Please????
    I have now deleted the source file and the batch monitor is still stuck on this clip – preventing me from starting any new compressions.
    It does seem to get stuck at the same point in each file. I have 9 different language versions of the same sequence with minor changes. Most have compressed without any problems but 2 keep getting stuck. Any suggestions for preventing this once I finally get rid of the ‘stuck’ clip, would also be appreciated.
    Any help or suggestions welcome. Thanks and have a lovely weekend!
    Running:
    Mac OSX v10.4.11
    FInal Cut Studio 2 (i.e. Compressor 3.0.3, Final Cut Pro 6.0.4, etc.)
  • Matt Babcock
    March 2, 2009 at 11:45 pm
    I just had the same problem but i was able to get rid of the rogue clip by repeatedly force quitting but the transcoding and compressor job controller from the activity monitor. I had restarted several times before this without any luck. Hope that works for you.
  • Dave Martin
    April 19, 2009 at 9:25 pm
    I’m having the exact same problem….seems to be one rogue file from fcp or a qt reference of it. Must keep force quitting for it to go away…
    Lots of time wasted this weekend…
    Dave Martin
    – MacPro – MacBook Pro –
