Activity › Forums › Apple Final Cut Pro Legacy › Batch Monitor – incoming network connection message
  • Batch Monitor – incoming network connection message
    Posted by Colin Lahana on November 14, 2010 at 11:24 am
    When I run Compressor i get the “Do you want the application “Batch Monitor.app” to accept incoming network connection. Whilst this is a common popup for lots of apps the problem with this one is that it only flicks onto the screen for about 3/25’s of a second and then disappears only to keep on popping up in this manner. Whilst Compressor is processing I cannot this interrupts any attempt to access such things as bookmarks or navigate through addresses in an internet browser.
    It’s very annoying. Does anyone know how to deal with this ?
    In order to identify this I had to film the screen and then work my way through the footage frame by frame to isolate it, hence why i could work out the 3/25 sec.
    Cheers
    Colin
    MacPro 2007
    SL 10.6.4
    FCS2
    Canon XL-H1 , 5D Mark II
    James Poulakos replied 15 years, 7 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    November 14, 2010 at 2:35 pm
    Reset your preferences for Compressor. Turn on the option to open batch monitor when a job is sent. Might fix you right up.
    If this fails try trashing this file: com.apple.compressor.Compressor.plist It’s in your user’s library in the Preferences folder there.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Chris Tompkins
    November 14, 2010 at 5:08 pm
    Also, turning off FireWall in System Pref/Security
    Stops this annoying behavior. Why Apple?
    Chris Tompkins
    Video Atlanta LLC
  • Colin Lahana
    November 21, 2010 at 3:07 am
    Cheers Jerry, Will try those out.
    Colin
    Cheers
    Colin
    MacPro 2007
    SL 10.6.4
    FCS2
  • James Poulakos
    March 1, 2011 at 10:29 pm
    Colin, did that work for you (trashing prefs)?
    It didn’t work for me. The same thing’s been happening to me for months. I trashed Compressor prefs, but it still happened.
    I think I found a clue: it happens at the same update time interval that’s in Batch Monitor’s preferences. So I can avoid it by not opening Batch Monitor (uncheck that box in Compressor’s prefs), or by setting Batch Monitor to update at a longer interval.
    I think I’ll go with the first option till I can find a better solution.
