Activity Forums Avid Media Composer Batch import not all audio tracks ie A1-3 just A1 gets imported
  • Batch import not all audio tracks ie A1-3 just A1 gets imported
    Posted by Ricky Milling on February 27, 2018 at 1:09 am
    Recently downgraded to 8.4.5 as i need it for another project. However, another one currently working on, everything is linked fine apart from audio for a pick up day.
    Here the audio seems to be offline apart from A1 (of three tracks).
    https://imgur.com/a/rgo8X
    Above shows before and after, as you can see for some the tracks are ok, but for others two fo the 3 tracks do not import.
    If i reimport from scratch all of the tracks are imported however this means i will have to re-sync a load of shots.
    Any ideas why this is happening?
    Audio problems
    Pat Horridge replied 8 years, 6 months ago 2 Members · 1 Reply
  • Pat Horridge
    February 28, 2018 at 7:03 am
    With batch import there is an option to override the initial import settings. It’s an extra bit ton you select and then you can override the track selection.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
