Activity Forums Adobe After Effects Batch File Process
  • Batch File Process
    Posted by Jhunyadi on January 12, 2006 at 5:02 pm
    I have a couple hundred :30 spots that need to be uploaded to a server. I have to convert these files from RTV (video toaster) to MPEG2. AE has been the best tool for me in the past, one file at a time… but is there an easy way to batch process these bad boys?
    Steve Roberts replied 20 years, 8 months ago 2 Members · 5 Replies
  • Steve Roberts
    January 12, 2006 at 6:05 pm
    Sorenson Squeeze?
  • Jhunyadi
    January 12, 2006 at 7:37 pm
    I tried that. Sorenson doesn’t work with .RTV files.
  • Steve Roberts
    January 12, 2006 at 7:54 pm
    Ugh. Try this:
    1. set up the default render settings and output modules to your desired settings
    2. select all 30 footage items in the project window
    3. drag them to the new comp button at the bottom of the project window
    4. in the dialog, check “multiple compositions” and “add to render queue”. Hit OK.
    You should have all those items in the render queue now, set to the default render settings and output modules.
    Give it a go …
    Steve
  • Jhunyadi
    January 12, 2006 at 9:52 pm
    Wow! That’s it! Thank You! You rock!
  • Steve Roberts
    January 13, 2006 at 12:08 am
    SR
